Winform python with SharpDevelop
Hi all,
Probably an easy question:
I just started to make a User Input inside python.
I found a program that helps me to create the form (SharpDevelop).
The form is created but I don’t have output.
How can I receive outputs?
import sys
clr.AddReference("System.Windows.Forms")
clr.AddReference("System.Drawing")
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
class Gebruikersinvoer(Form):
	def __init__(self):
		self.InitializeComponent()
	def InitializeComponent(self):
		self._combov_verd = System.Windows.Forms.ComboBox()
		self._button1 = System.Windows.Forms.Button()
		self._label2 = System.Windows.Forms.Label()
		self._label3 = System.Windows.Forms.Label()
		self._label4 = System.Windows.Forms.Label()
		self._text_projectnr = System.Windows.Forms.TextBox()
		self._text_projectnaam = System.Windows.Forms.TextBox()
		self._label1 = System.Windows.Forms.Label()
		self._text_blok = System.Windows.Forms.TextBox()
		self._label5 = System.Windows.Forms.Label()
		self._text_tek = System.Windows.Forms.TextBox()
		self._combo_formaat = System.Windows.Forms.ComboBox()
		self._label6 = System.Windows.Forms.Label()
		self.SuspendLayout()
		# combov_verd
		self._combov_verd.FormattingEnabled = True
		self._combov_verd.Items.AddRange(System.Array[System.Object](
			["00 fundering",
			"01 verdieping",
			"02 verdieping",
			"03 verdieping",
			"04 verdieping",
			"05 verdieping",
			"06 verdieping",
			"07 verdieping",
			"08 verdieping",
			"09 verdieping",
			"10 verdieping",
			"11 verdieping",
			"12 verdieping",
			"13 verdieping",
			"14 verdieping",
			"15 verdieping",
			"16 verdieping",
			"17 verdieping",
			"18 verdieping",
			"19 verdieping",
			"20 verdieping"]))
		self._combov_verd.Location = System.Drawing.Point(294, 127)
		self._combov_verd.Name = "combov_verd"
		self._combov_verd.Size = System.Drawing.Size(121, 21)
		self._combov_verd.TabIndex = 0
		self._combov_verd.SelectedIndexChanged += self.ComboBox1SelectedIndexChanged
		# button1
		self._button1.Location = System.Drawing.Point(303, 205)
		self._button1.Name = "button1"
		self._button1.Size = System.Drawing.Size(112, 27)
		self._button1.TabIndex = 2
		self._button1.Text = "Voltooien"
		self._button1.UseVisualStyleBackColor = True
		self._button1.Click += self.Button1Click
		# label2
		self._label2.Location = System.Drawing.Point(27, 25)
		self._label2.Name = "label2"
		self._label2.Size = System.Drawing.Size(111, 23)
		self._label2.TabIndex = 1
		self._label2.Text = "Projectnummer"
		# label3
		self._label3.Location = System.Drawing.Point(27, 48)
		self._label3.Name = "label3"
		self._label3.Size = System.Drawing.Size(111, 23)
		self._label3.TabIndex = 1
		self._label3.Text = "Projectnaam"
		# label4
		self._label4.Location = System.Drawing.Point(27, 125)
		self._label4.Name = "label4"
		self._label4.Size = System.Drawing.Size(111, 23)
		self._label4.TabIndex = 1
		self._label4.Text = "Selecteer verdieping"
		# text_projectnr
		self._text_projectnr.Location = System.Drawing.Point(294, 28)
		self._text_projectnr.Name = "text_projectnr"
		self._text_projectnr.Size = System.Drawing.Size(121, 20)
		self._text_projectnr.TabIndex = 3
		# text_projectnaam
		self._text_projectnaam.Location = System.Drawing.Point(294, 51)
		self._text_projectnaam.Name = "text_projectnaam"
		self._text_projectnaam.Size = System.Drawing.Size(121, 20)
		self._text_projectnaam.TabIndex = 3
		# label1
		self._label1.Location = System.Drawing.Point(27, 74)
		self._label1.Name = "label1"
		self._label1.Size = System.Drawing.Size(111, 23)
		self._label1.TabIndex = 1
		self._label1.Text = "Bloknummer"
		self._label1.Click += self.Label1Click
		# text_blok
		self._text_blok.Location = System.Drawing.Point(294, 77)
		self._text_blok.Name = "text_blok"
		self._text_blok.Size = System.Drawing.Size(121, 20)
		self._text_blok.TabIndex = 3
		# label5
		self._label5.Location = System.Drawing.Point(27, 100)
		self._label5.Name = "label5"
		self._label5.Size = System.Drawing.Size(111, 23)
		self._label5.TabIndex = 1
		self._label5.Text = "Tekenaar"
		self._label5.Click += self.Label1Click
		# text_tek
		self._text_tek.Location = System.Drawing.Point(294, 103)
		self._text_tek.Name = "text_tek"
		self._text_tek.Size = System.Drawing.Size(121, 20)
		self._text_tek.TabIndex = 3
		# combo_formaat
		self._combo_formaat.FormattingEnabled = True
		self._combo_formaat.Items.AddRange(System.Array[System.Object](
			["A2"]))
		self._combo_formaat.Location = System.Drawing.Point(294, 152)
		self._combo_formaat.Name = "combo_formaat"
		self._combo_formaat.Size = System.Drawing.Size(121, 21)
		self._combo_formaat.TabIndex = 0
		self._combo_formaat.SelectedIndexChanged += self.ComboBox1SelectedIndexChanged
		# label6
		self._label6.Location = System.Drawing.Point(27, 150)
		self._label6.Name = "label6"
		self._label6.Size = System.Drawing.Size(111, 23)
		self._label6.TabIndex = 1
		self._label6.Text = "Selecteer formaat"
		self._label6.Click += self.Label6Click
		# MainForm
		self.AutoSize = True
		self.ClientSize = System.Drawing.Size(434, 253)
		self.Controls.Add(self._text_tek)
		self.Controls.Add(self._text_blok)
		self.Controls.Add(self._text_projectnaam)
		self.Controls.Add(self._label5)
		self.Controls.Add(self._text_projectnr)
		self.Controls.Add(self._label1)
		self.Controls.Add(self._button1)
		self.Controls.Add(self._label3)
		self.Controls.Add(self._label2)
		self.Controls.Add(self._label6)
		self.Controls.Add(self._combo_formaat)
		self.Controls.Add(self._label4)
		self.Controls.Add(self._combov_verd)
		self.MaximizeBox = False
		self.MinimizeBox = False
		self.Name = "MainForm"
		self.ShowIcon = False
		self.Text = "Gebruikersinvoer"
		self.ResumeLayout(False)
		self.PerformLayout()
	def Button1Click(self, sender, e):
		self.Close()
	def ComboBox1SelectedIndexChanged(self, sender, e):
		pass
	def Label1Click(self, sender, e):
		pass
	def Label6Click(self, sender, e):
		pass
form = Gebruikersinvoer()
Application.Run(form)
OUT = 0
@jw.vanasselt you can enhance it more if you want, a list is needed in the form to host the values as per your objects, Text(Property) for texts and SelectedItem for combo boxes once you click the Complete button:
WinForm.dyn (11.1 KB)
That’s great! That was the answer I was looking for. :slight_smile:
@jw.vanasselt what did you use to make the form and is it free?
I have been trying to get down to forms in Python and it is quite painful. Would love to develop forms ad back end in Visual studio or the like and export it.
~TIA
Hi @Ron_Allen ,
I use sharpdevelop, it is really easy and free !
You have a design tab and the source is available :slight_smile:
