Hi All, - I’m following this python forms tutorial on Youtube [https://www.youtube.com/watch?v=J-DIXsT7zug], before I spin off my own one for my project - but the code doesn’t seem to be working? - Well, I think I’ve missed a reference file somewhere?
I’ve attached the dyn but here’s the core code.
Forms.dyn (6.5 KB)
> # Enable Python support and load DesignScript library
> import clr
> import System
> clr.AddReference('System.Windows.Forms')
> clr.AddReference('System.Drawing')
> from Systems.Windows.Forms import*
> from System.Drawing import*
> # Create a class form
> class CreateWindow(Form):
> def _init_(self)
> # Create Form
> self.Name = 'Create Window'
> self.Text = 'Create Window'
> self.Size = Size(500, 150)
> self.CenterToScreen()
> self.values = []
> #Create label for sheet name
> labelSheetName = Label(Text = "Sheet Name"
> labelSheetName.Parent = self
> labelSheetName.Location = Point(30,20)
> #Create label for Sheet number
> labelSheetName = Label(Text = "Sheet Number"
> labelSheetName.Location = Point(30,50)
> #Create textbox for sheet name
> self.textboxSheetName = TextBox()
> self.textboxSheetName.Parent = self
> self.textboxSheetName.Text = "Sheet Name"
> self.textboxSheetName.Location = Point(150,20)
> self.textboxSheetName.Width = 150
> #Create textbox for sheet number
> self.textboxSheetNumber = TextBox()
> self.textboxSheetNumber.Parent = self
> self.textboxSheetNumber.Text = "Sheet Number"
> self.textboxSheetNumber.Location = Point(150,50)
> self.textboxSheetNumber.Width = 150
> #Create Button
> button = Button()
> button.Parent = self
> button.Text = "OK"
> button.Location - point(400)
> #Register Event
> button.Click += self.ButtonClicked
> def ButtonClicked(self,sender args):
> if sender.Click:
> self.values.append(Self.textboxSheetName.Text)
> self.values.append(Self.textboxSheetNumber.Text)
> self.Close()
> # The inputs to this node will be stored as a list in the IN variables.
> if IN[0]:
> form = CreateWindow()
> Application.Run(form)
> # Assign your output to the OUT variable.
> OUT = form.values
Line 6: from Systems.Windows.Forms import* should be from System.Windows.Forms import *. Just a minor typo–everything should work after that.
Not 100% but i think i corrected the typos.
I still get the message: unexpected token ‘labelSheetName’
import System
from Systems.Windows.Forms import *
from System.Drawing import *
run = IN[0]
def _init_(self):
# Create Form
self.values = []
labelSheetName = Label(Text = "Sheet Name")
#Create Button
button = Button()
button.Text = "OK"
#Register Event
if sender.Click:
self.Close()
if run:
OUT = form.values
Here is a fixed version:
import System
run = IN[0]
def __init__(self):
# Create Form
self.values = []
labelSheetName = Label(Text = "Sheet Number")
#Create Button
button = Button()
button.Text = "OK"
button.Location = Point(400)
#Register Event
def ButtonClicked(self, sender, args):
if sender.Click:
self.values.append(self.textboxSheetName.Text)
self.values.append(self.textboxSheetNumber.Text)
self.Close()
if run:
OUT = form.values
Mainly just syntax fixes
Problem is… i keep getting an error:
IronPython.Runtime.UnboundNameException: global name ‘Self’ is not defined
em IronPython.Runtime.Operations.PythonOps.GetVariable(CodeContext context, String name, Boolean isGlobal, Boolean lightThrow)
em IronPython.Compiler.LookupGlobalInstruction.Run(InterpretedFrame frame)
em Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame)
Is there a way to correct this? Thanks!
Oops, looks like I missed one last typo. The ‘Self’ should be lowercase for the ButtonClicked() function.
Ahaa Thanks! Wouldn’t have noticed the * error! Still getting the hang of everything syntax wise
The fix was actually changing Systems to System. I added a space between import and the asterisk as that is what is typically done.
