It could probably be made better by making Masses (generated from from the Flux building models) extrusions instead of DirectShapes. Optimizing and categorizing lines would be good, too.
Building models came in shifted in position – I had to move them to line-up with the footprints.
Street name and width data do not come through the Flux Site Extractor. However, here’s a trick to get that info back into a plan view. Put in an image from a map and fit it onto the Revit model elements:
@truevis did you have any luck controlling the surface projection colour of the imported building masses? I would like to remove the mesh triangulation.
