Flip Work Plane Equivalent
I am trying to flip several families and I was wondering if there was a node or method in Python to access the flip work plane action/button
I’ve tried several flip face orientation nodes but they had no effect and I am aware of the ability to mirror or rotate but ideally I would like to access the flip work plane command if possible. I know there has been an example in the API so I do believe it is possible. Anyone have a quick solution? Thanks!
@Dynamonkey
these two nodes from Clockwork package should do what you want
Hi @Dynamonkey,
If you want to get jiggie with python I think the FamilyInstance method flipFacing() might be what you want.
Although, i would use @Mostafa_El_Ayoubi’s solution. Easier.
Cheers,
Dan
Hey @Daniel_Woodcock1 & @Mostafa_El_Ayoubi
I will take a look again but yes as mentioned in my post, I’ve tried those flip face nodes but unfortunately had no success. I have a feeling python is the way to go. The API example I was referring to calls for:
famInst.IsWorkPlaneFlipped = true
is there any equivalent for this in Python?
Hi @Dynamonkey,
Instead of elem.flipFacing() Just use elem.IsWorkPlaneFlipped(b) where “b” is a bool value.
There are several flip methods (although the one you mention is a property).
Family Instance Members (Flip)
Family Instance Properties (Flip)
I think we are getting closer. I did a quick test literally adding onto the python code in the FlipFacing node by adding IN[1] to receive a Boolean toggle value and switching item.FlipFacing() to item.IsWorkPlaneFlipped(b) where b = IN[1]. Output is empty and family instance(s) remains unchanged.
Hi @Dynamonkey,
Sorry, it was my fault, I made a mistake with how I told you to set the property (rookie mistake). Properties need to be set with an = so elem.IsWorkPlaneFlipped = b and not elem.IsWorkPlaneFlipped(b).
It seems to work fine here, see below (script attached also)…
FlipComponent.dyn (5.5 KB)
Cheers,
Dan
Now that’s what I call teamwork. Glad we got this one sorted out.
Is there any way we can apply the same principle to do it for multiple elements? I tried replacing the node with the one for multiple elements but it wouldn’t work.
Hi @Viraj_Voditel1,
Yes, this is pretty simple. The following demostrates how to do this…
doc =  DocumentManager.Instance.CurrentDBDocument
clr.AddReference("RevitAPI")
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
elems = tolist(UnwrapElement(IN[0]))
bools = tolist(IN[1])
for elem,b in zip(elems, bools):
Hope this helps.
Cheers,
Dan
Hi @Daniel_Woodcock1
I’ve tried to run your script with multiple but it will only slip one still? I also have an error I don’t know how to fix in the python script. Are you able to provide some help or spot the one thing I am missing?
Thanks if you can!
Hi @Jade,
Yes, two problems I can see.
  1. The Boolean list needs to have the same number of bools as you do elements. It’s a 1:1 operation as the elements/bools are zipped.
  2. You are trying to flip a tag element and this doesn’t support flipping (the yellow balloon warning message) since they are not hosted to planes as they are 2d elements. I don’t think tags actually support flipping at all, only switching between orientation (horizontal/vertical) or changing their Family Type.
Hope this solves your problem.
Cheers,
Dan
Thanks for responding. Where do I place 1. Do I have that in the code block and adjust the list or do I need to place the value in the python script?
  1. is working fine, it flips tagged or untagged, it just only flips one instead of all. Which ^ should fix hopefully!
Kind regards
HI @Jade,
Yeah, you have 2 boolean values in the code block, but the number of these needs to match the number of elements you want to flip. So, in this instance, you need 7 as you have 7 Elements in the Select Model Elements node.
if you only need True or only need false, use the List.Cycle node. See examples below…
Hi @Daniel_Woodcock1 thank you for responding I am sure this will work now when I test run! Thank you again for being so helpful much appreciated!
Hi Daniel_Woodcock1,
Where is that image you posted of the properties from?
Thanks,
Thank you for your help @Daniel_Woodcock1. Much Appreciated.
The FlipFacingOrientation node has the same port for in and out (familyInstance) these are usually different.
The newer nodes have extra ports as well.
I can get my script to point at all selected light fixtures, but nothing happens in the model.
Hello,t
I would like to flip those lighs fixtures, I ve tried lots methodes and script.
But idea using dynamo. Someone have idea ?
Light fixtures are PLANE based and insert upside down 9 times out of 10 unless you build them the right way.
I will write a “flipper” script for you.
