Hi everyone,
I used to use Firefly in Grasshopper I have no problems with it, my problem in Dynamo is the mega read node dose not read automatically because I cant find timer like in Grasshopper.
Hi everyone,
Try setting your run-mode to periodic instead of automatic and it should work.
Thank you very much it is working now.
You mean changing the node .Getportsavailable ?
Firefly for Dynamowhere are download
Firefly can be downloaded via the in-product package manager, or via the web portal at Dynamopackages.com.
More info on packages can be found here:
https://www.dynamoprimer.com/11_Packages/11-1_Introduction.html
Since this topic has had two multi-year long pauses in replies I will be closing it now. If you have difficulties working with Firefly please start a new topic with all relevant info (graph, data set, and clear description if the issue).
