Finding something from API for Tool.AssemblyView
Hi, I’m trying to add Create Generic Model Schedule to the Tool.AssemblyViews node. I’m struggling to find it in the 2017.1 API website. Never used it so I’m pretty lost. Got here. Maybe its CreateSingleCategorySchedule Method? Help would be greatly appreciated. Even with adding the code if its simple for you. I’m bound to screw it up
#python nodes in dynamo 1.0
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
elt = []
for i in IN[0]:
	elt.append(UnwrapElement(i).Id)
tb=UnwrapElement(IN[13]).Id
catid=doc.GetElement(elt[0]).Category.Id
collection=List[ElementId](elt)
viewlist=[]
schedlist=[]
sheetlist=[]
# Start Transaction
for a in elt:
	views=[]
	if IN[1] == 1:
		v=AssemblyViewUtils.Create3DOrthographic(doc,a)
		views.append(v)
	if IN[2] == 1:
		ds2=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.HorizontalDetail)
		views.append(ds2)
	if IN[3] == 1:
		ds3=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationTop)
		views.append(ds3)
	if IN[4] == 1:
		ds4=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationBottom)
		views.append(ds4)
	if IN[5] == 1:
		ds5=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationLeft)
		views.append(ds5)
	if IN[6] == 1:
		ds6=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationRight)
		views.append(ds6)
	if IN[7] == 1:
		ds7=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationFront)
		views.append(ds7)
	if IN[8] == 1:
		ds8=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationBack)
		views.append(ds8)
	if IN[9] == 1:
		ds9=AssemblyViewUtils.CreatePartList(doc,a)
		views.append(ds9)
	if IN[10] == 1:
		ds10=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.DetailSectionA)
		views.append(ds10)
	if IN[11] == 1:
		ds11=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.DetailSectionB)
		views.append(ds11)
	viewlist.append(views)
	if IN[12] == 1:
		sh=AssemblyViewUtils.CreateSheet(doc,a,tb)
		for v in views:
			if Viewport.CanAddViewToSheet(doc,sh.Id,v.Id) == 1:
				Viewport.Create(doc,sh.Id,v.Id,XYZ(0,0,0))
				ScheduleSheetInstance.Create(doc,sh.Id,v.Id,XYZ(0,0,0))
		sheetlist.append(sh)
doc.Regenerate()
# End Transaction
OUT=viewlist,sheetlist
tried changing this
if IN[9] == 1:
		views.append(ds9)
to
if IN[9] == 1:
		ds9=AssemblyViewUtils.CreateSingleCategorySchedule(doc,a)
		views.append(ds9)
no luck though
I don’t know if it will help, but this method seems to have at least 3 parameters instead of 2:
CreateSingleCategorySchedule(Document, ElementId, ElementId)
CreateSingleCategorySchedule(Document, ElementId, ElementId, ElementId, Boolean)
Thanks man, theres also an example under AssemblyViewUtils Class that uses CreateSingleCategory Schedule. I dont know enough to do anything with it all though. Heres the node below if anyone can help
Tool.AssemblyViews.AddedGenricSchedule.dyf (15.4 KB)
I suppose you’ve seen this thread already:
Thanks but i’m not sure if it helps me. Have 140 assemblies to create a generic model schedule for. Might just do this one by hand.
so far to do this task we use this one.
would be great to see it in the Too.AssemblyView Node.
Assembly - 03 - Multiple Schedule from Template.dyn (24.7 KB)
