Tool.assemblyviews
this script is work perfectly but i need fabrication schedule instead of partlist. if anyone know the solution to rewrite this script please help with this.
Developers nodes in dynamo 1.0
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
#Import ToDSType(bool) extension method
#Import geometry conversion extension methods
#Import DocumentManager and TransactionManager
#Import RevitAPI
clr.AddReference(“RevitAPI”)
app = uiapp.Application
elt =
for i in IN[0]:
elt.append(UnwrapElement(i).Id)
tb=UnwrapElement(IN[13]).Id
catid=doc.GetElement(elt[0]).Category.Id
collection=ListElementId
viewlist=
schedlist=
sheetlist=
#Start Transaction
for a in elt:
views=
if IN[1] == 1:
v=AssemblyViewUtils.Create3DOrthographic(doc,a)
views.append(v)
if IN[2] == 1:
ds2=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.HorizontalDetail)
views.append(ds2)
if IN[3] == 1:
ds3=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationTop)
views.append(ds3)
if IN[4] == 1:
ds4=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationBottom)
views.append(ds4)
if IN[5] == 1:
ds5=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationLeft)
views.append(ds5)
if IN[6] == 1:
ds6=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationRight)
views.append(ds6)
if IN[7] == 1:
ds7=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationFront)
views.append(ds7)
if IN[8] == 1:
ds8=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationBack)
views.append(ds8)
if IN[9] == 1:
ds9=AssemblyViewUtils.CreatePartList(doc,a)
views.append(ds9)
if IN[10] == 1:
ds10=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.DetailSectionA)
views.append(ds10)
if IN[11] == 1:
ds11=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.DetailSectionB)
views.append(ds11)
viewlist.append(views)
if IN[12] == 1:
sh=AssemblyViewUtils.CreateSheet(doc,a,tb)
for v in views:
if Viewport.CanAddViewToSheet(doc,sh.Id,v.Id) == 1:
Viewport.Create(doc,sh.Id,v.Id,XYZ(0,0,0))
ScheduleSheetInstance.Create(doc,sh.Id,v.Id,XYZ(0,0,0))
sheetlist.append(sh)
doc.Regenerate()
End Transaction
OUT=viewlist,sheetlist
@sovitek i need assitance for this sir
Hi @bim6MRER3 sorry i cant help you. as i dont work in fabrication…
If you can’t get what you need from a Parts List, a Specialty Equipment schedule or a Material Takeoff, then you will probably have to create a regular multi-category schedule and use filters to get only the elements that relate to the assembly. You can still create the schedule and insert it onto your assembly sheet as part of your main graph/script, however you may have to use transactions to control the flow of operation.
thanks for your info sir
Is there a node that will create a Specialty Equipment Schedule from an assembly?
Not directly, that I am aware of. But under View Templates, you can create a “Schedules” view type template and have “Category” as one of the fields. Then set a filter for “Category” “equals” “Specialty Equipment”. From that point, set up a dynamo script to create a parts list from a selected assembly and have it apply the view template to that schedule.
That’s awesome! I’ll look into that. Thanks!
