Creating Structural Rebar Schedule for Assembly Views
Hello I was Wondering if anyone could help me create a Structural rebar category schedule for my assemblies. I am creating views and Schedules using the Tool.Assemblyviews node from Steam Nodes but the schedules that get created are multi category schedules that cannot access the Structural Rebar schedule category fields. If anyone knows a way around this please let me know
Set up ^
Python
`#python nodes in dynamo 1.0
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
elt = []
for i in IN[0]:
	elt.append(UnwrapElement(i).Id)
tb=UnwrapElement(IN[17]).Id
catid=doc.GetElement(elt[0]).Category.Id
collection=List[ElementId](elt)
viewlist=[]
schedlist=[]
sheetlist=[]
# Start Transaction
for a in elt:
	views=[]
	if IN[1] == 1:
		v=AssemblyViewUtils.Create3DOrthographic(doc,a)
		views.append(v)
	if IN[2] == 1:
		ds2=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.HorizontalDetail)
		views.append(ds2)
	if IN[3] == 1:
		ds3=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationTop)
		views.append(ds3)
	if IN[4] == 1:
		ds4=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationBottom)
		views.append(ds4)
	if IN[5] == 1:
		ds5=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationLeft)
		views.append(ds5)
	if IN[6] == 1:
		ds6=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationRight)
		views.append(ds6)
	if IN[7] == 1:
		ds7=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationFront)
		views.append(ds7)
	if IN[8] == 1:
		ds8=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationBack)
		views.append(ds8)
	if IN[9] == 1:
		ds9=AssemblyViewUtils.CreatePartList(doc,a)
		views.append(ds9)
	if IN[10] == 1:
		ds10=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.DetailSectionA)
		views.append(ds10)
	if IN[11] == 1:
		ds11=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.DetailSectionB)
		views.append(ds11)
	if IN[12] == 1:
		ds12=AssemblyViewUtils.CreateMaterialTakeoff(doc,a)
		views.append(ds12)
	if IN[13] == 1:
		ds13=AssemblyViewUtils.CreatePartList(doc,a)
		views.append(ds13)
	if IN[14] == 1:
		ds14=AssemblyViewUtils.CreatePartList(doc,a)
		views.append(ds14)
	if IN[15] == 1:
		ds15=AssemblyViewUtils.CreatePartList(doc,a)
		views.append(ds15)
	viewlist.append(views)
	if IN[16] == 1:
		sh=AssemblyViewUtils.CreateSheet(doc,a,tb)
		for v in views:
			if Viewport.CanAddViewToSheet(doc,sh.Id,v.Id) == 1:
				Viewport.Create(doc,sh.Id,v.Id,XYZ(0,0,0))
				ScheduleSheetInstance.Create(doc,sh.Id,v.Id,XYZ(0,0,0))
		sheetlist.append(sh)
doc.Regenerate()
# End Transaction
OUT=viewlist,sheetlist`
Hello
it is necessary to use this method
here an example
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lst_assemblies = toList(UnwrapElement(IN[0]))
category = UnwrapElement(IN[1])
schedule_template = UnwrapElement(IN[2])
out = []
for assemb in lst_assemblies:
	if DB.ViewSchedule.IsValidCategoryForSchedule(category.Id):
		scheduleViewAssemb = DB.AssemblyViewUtils.CreateSingleCategorySchedule (doc, assemb.Id, category.Id, schedule_template.Id, False)
		out.append(scheduleViewAssemb)
OUT = out
THANK YOU!!
The schedule gets created however the view template doesn’t get applied for some reason. I just added an Add viewtemplate node after it to get around it and it works perfectly.
I have tried same way to create view but as per above image error found can any one Tell me why this error occured?How to fix this?
