Hello everyone, is there an effective way to filter out special characters within Dynamo. I want to filter them out from the view names so that views with the name does not get renamed.
Hello @annickad and welcome to the forum…do you mean something here ?
One way to do it in python
, there will be a bunch more…
a
find_these = "\:\{}[]|;<>?'~]"
name_result = []
view_result = []
names = IN[0]
views = IN[1]
for n,v in zip(names,views):
check = 0
for f in find_these:
if f in n:
check = + 1
break
if check != 1:
name_result.append(n)
view_result.append(v)
OUT = name_result,view_result
a solution using NamingUtils
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
toList = lambda x : x if isinstance(x, list) else [x]
lstElement = toList(UnwrapElement(IN[0]))
OUT = [e for e in lstElement if e is not None and DB.NamingUtils.IsValidName(e.Name)]
