Import CAD text (Layer names with special characters)
I’m attempting to retrieve CAD text data, but my CAD file contains layers with names containing special characters. As a result, the Bimorph “CADTextData.FromLayers” node is not working. Is there an alternative method to obtain CAD text data in Dynamo without renaming the CAD layers?
@vishalghuge2500 ,
from python i know these sentence at the begin at anny code so can work with all symbols
# -*- coding: utf-8 -*-
try nodes from GeniusLoci
hi,
you can use special character in your cad layers. likes i also using special character on cad.
you can use this flow and try than you got the solution.
@Draxl_Andreas
Sorry, I’m a noob in coding, so I don’t understand.
Is there any other node similar to Bimorph “CADTextData.FromLayers” node
