Alter View templates in project via dynamo
Hi All
Im after help on how to grab all active View templates within my revit project with dynamo and turn off the import element of VG so that all my views do not get contaminated with imported AutoCAD dwg.
Ideally, I need this as a dynamo script as I have hundreds of projects to repair.
I may want to filter by view name, i.e., begins with “XX.”
I’m not sure this function is available in Revit API, a workaround is to disable categories (CADLink)
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
viewtemplates = DB.FilteredElementCollector(doc).OfClass(DB.View).ToElements().FindAll(lambda x : x.IsTemplate)
cadlinkTypes = DB.FilteredElementCollector(doc).OfClass(DB.CADLinkType)
for view in viewtemplates:
	if view.Name.startswith("XX."):
		for cadlLnkType in cadlinkTypes:
			if Element.Name.GetValue(cadlLnkType).endswith(".dwg"):
				view.SetCategoryHidden(cadlLnkType.Category.Id, True)
OUT = cadlinkTypes
Hi
Thanks for this, im totally new to the dynamo, how do I use this in a script. Does this need adding to a python node then attached to some input / outputs?
Just copy and paste inside a python Node
That’s great.
one more question how can I get this to look fo more than one type
Example
“XX”
“01_”
“02_”
“03_”
Many thanks in advance
startswith() method can accept a tuple as a parameter
if view.Name.startswith(("XX", "01_", "02_", "03_")):
