Hello dynamo developers and users, I am seeking for help in some problem that I’m facing as I’m new in using dynamo for the last 2 month.
The problem I’m facing is that when I’m collecting exterior wall orientation using the custom nodes ‘Wall.ExteriorDirection’ under “archilab”, I’m able to get the correct orientation for flat surface wall but I couldn’t get the correct orientation for curve wall/circular wall as the result will give me opposite orientation. one of the solution that I use was to use the nodes ‘Vector.Reverse’ to get the correct orientation for the curve wall by reversing the vectors.
So what I thought was if let say I have both curve wall and flat wall surface in a building model, is there any nodes allow me to filter between flat wall and curve wall as I don’t want the node ‘Vector.Reverse’ to affect the flat wall orientation when the orientation for flat surface wall are already correct.
