Hi Everyone,
Could anyone please tell me how to filter Solid from a list which contain Solid and Arc.
Thank you very much
It should be as easy as using the “RemoveIfNot” node, but it seems to be broken. So you could try this instead:
Try “RemoveIfNot” with the string “Autodesk.Solid” instead of just “Solid.” I believe other packages are registering “Solid” and there is a conflict.
Correct. Lunchbox’s ZT nodes are using the Solid namespace and that was interfering with it. Thanks!
Great! thank you, @Dimitar_Venkov
