How to test geometry if it's solid or not?
if i have a list of lists with geometries, solids and meshes etc.
Is there a way to filter out only solid geometry? i can’t seem to find a way to test this, except for converting the geometry to string and matching it on string basis but that seems dumb…
Hi @Garbage_Collector you could try object type for see whitch objecttype…and for filter out i like remove if not
As always, really helpful and very fast :slight_smile:
I used the object.type and filterbyboolmask, since i need the original list of geometries so i dont think i can use remove ifnot
yeah or just as here
:man_facepalming:
I did not know you could do that haha
Thank you, that’s a lot cleaner
