Filter geometry list to only show solids
Probably a dumb question. This cant be the best way to filter the list to only contain solid geometry right?
Hi @Garbage_Collector you can try remove if not…
Thank you!
I was looking for how to compare geometry to a solid, your codeblock shows what to use instead of a string heh :slight_smile:
I was too fast…
For some reason it returns an empty list
Edit : I just now see the .Dictionary in there… It works :slight_smile:
yeps thats the thing :wink:
You might be able to just use ‘Solid’ depending on how your Dynamo environment is set up (i.e. Dynamo for Civil 3D has a “Solid” class as well so you get namespace collision issues).
That’s good to know thank you!
yeah you can always find out with use objectype node i guess :wink: :wink:
Often the full namespace (Autodesk.DesignScript.Geometry.YourGeometryTypeHere) is good to include as it will help the graph to scale - you don’t know how the next user’s environment is configured.
