Fill only the empty values
i created a dynamo script to rename my structural elements i want to know if it’s possible: if the elements has a name already it ignores it and goes to the next element that doesn’t have a name thank you in advance.
@nizarmalek10 ,
you can use a codeblock like …
x == ""? "Empty" : x #copy into codeblock
Prefilter your values - test it!
KR
Andreas
Push your filtered list into another get parameter value by name node and use the codeblock that @Draxl_Andreas is showing to filter that list based on the parameter being empty or not. Then push that filtered list into the set parameter by name node.
