Hi all!
How can we get the file path of the currently opened Revit File linked with Dynamo? I cannot find the Get Current Revit Document Path.dyf node from clockwork anymore.
Thank you
Hi all!
Thank you
Thank you for the reply! This is helpful but is there a way to convert the string to a path, basically i want to use this instead of the file.path node Is it possible
File path returns a string, no conversion is needed.
