Get the file name of the active revit document
I’m wondering if it is it possible to get the file name of the active Revit document automatically using dynamo without having to manually browse for it.
I currently use the FilePath.FileName node, connected to the file path browse node; but this method requires the user to manually browse for the file when opening different projects.
Thanks for any help in advance.
Hi Mark,
Here is one of the possible way using Python.
@Mark_246
there is a node in node mode usineg the same API method as the one mentionned in kulkul’s reply, it gives the document name and the file path :
Nodes available OOTB …
Thanks for the assistance, all sorted now!
I would find the node you show, where can I find it ?
hi @c.barribaud ,
I’m not maintaining node-mode anymore and I didn’t move this node to Data-Shapes. Here’s the code though if wou want it :
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
path = doc.PathName
docname = path.encode('string-escape')
OUT = docname.split('\\\')[-1] , path
you can also do it with ootb nodes :
May I ask something: will you maintain the Data-Shapes package in the future? :slight_smile:
Absolutely! :slight_smile:
Absolutely wonderful! :grinning:
There was a formatting error in the text- this gets just the filename form the document path:
path = doc.PathName
OUT = (path.split('/')[-1]).split('.')[0]
The “Title” property of the Document can also be used (additional documentation here).
Note: The Document.Title property returns the title without the extension in the Revit 2019 API, although the above code would still work with the 2019 API.
I am trying to retrieve the name of the current Revit Document. I have tried two nodes, and neither seem to work.
What am I missing?
I just saw that there is an update from 2.02 to 2.03. Installed it and it now works!
It’s happen when your project file is not saved…
