FamilyType.VoidbyGeometry
I need to create a void family by using revit geometry . I found a node as indicated below, but I couldn’t understand how to use it exactly. (I do not find what does “templatePath” part require?")
Thank you in advance :slight_smile:
This requires the path to the Revit family template you want to use.
The FamilyInstance.ByGeometry node in the springs package may be more useful in your specific case.
Thank you for the node advise. I will try it. In addition, could you please share a sample how to add path for the previous node. Probably I missed something. :slight_smile:
Use a File Path node to point to a Revit family template, or paste the location (ie: c://someFolder/someFamily.rft).
Thank You, it works. :slight_smile:
