FamilyType.Duplicate not working in 2017 / 2018
Hello All,
I’m having some issues with the FamilyType.Duplicate node from the clockwork package (I’ve also tried the springs equivalent) in Revit 2017 / 2018. I’ve tried using both 1.3.4 & 2.0.2 Dynamo and even some legacy versions of clockwork - but I get the same issues:
Here is the node working correctly in Revit 2019 (with DYN 2.0.2):
FamilyTypeDuplicate1
… and here is the issue I’m seeing in 2017 / 2018:
FamilyTypeDuplicate2
Does anyone have any suggestions on what might be causing this?
Cheers,
Martin
Beat way to debug this yourself is to open the Clockwork node up to see the contents, and move the functions into the Dynamo graph via copy/paste.
Hi @PowellDesign
Here is another possible way to write in python which i tested in Revit 2017/18/19, Dynamo ver 1.3x and 2.0x :
# Import RevitAPI
clr.AddReference('RevitAPI')
result = []
famtype = UnwrapElement(IN[0])
dupnames = IN[1]
for s in dupnames:
    newsymbol = famtype.Duplicate(s)
    result.Add(newsymbol.ToDSType(True))
OUT = result
