FamilyType.ByName - strange behaviour
Hi all,
I’m trying to create a script in which I can select an elementtype by name. I would expect the script shown below to work but it does not, can anyone explain why?
Thanks in advance
Hi, try this methode:
code for copy/pasting:
clr.AddReference(‘RevitAPI’)
from Autodesk.Revit.DB import BuiltInParameter, FilteredElementCollector
el_types = FilteredElementCollector(doc).WhereElementIsElementType().ToElements()
for i in el_types:
name = i.get_Parameter(BuiltInParameter.SYMBOL_NAME_PARAM).AsString()
if name ==IN[0]:
type = i
OUT = type
thanks a lot, your solution worked.
The tabs are missing from the copy/paste part of your answer so I added those:
clr.AddReference("RevitAPI")
for i in el_types:
	if name ==IN[0]:
		type = i
OUT = type
