Call FamilyType.ByFamilyNameAndTypeName from Python Node
I am newbee in Python and APIs so sorry if this question too silly.
How can I call FamilyType.ByFamilyNameAndTypeName function from Python?
I’ve tried code like this, but faced with “AttributeError: ‘Autodesk.Revit’ object has no attribute ‘Elements’” issue.
tp = IN[0]
# Place your code below this line
get_fam = Autodesk.Revit.Elements.FamilyType.ByFamilyNameAndTypeName('Wall_Junction_Type_Test', 'T')
OUT = get_fam
That’s stange because prompt gave me a hint to select “Elements”. My logic to find apropriate node was following: I followed through the every category and subcategory to the place where node belongs to separated by point.
What is your input? (IN[0])
What is it that you want?
Did you import the sys?
Hi, @jw.vanasselt
Information from IN[0] is not my input. I hardcoded family name and family type.
Yes, I used to import sys.
you have some missing library import
import sys
get_fam = Revit.Elements.FamilyType.ByFamilyNameAndTypeName('M_Double-Flush', '1730 x 2134mm')
OUT = get_fam
Thank you!
