I`m working with the Familytype.ByGeomtry node. It works fine but is scales all the geometry as created in dynamo with a factor 4. Does anyone has an idea to fix this?
See below printscreen. Attached is the dynamo script.
bosk.dyn (104.8 KB)
@wouter.hilhorst i have this same issue. did you find any resolution?
It could also work, but the node from synthesize is better
