Edited by moderator. See below the line for original post.
I have a problem with a project I am doing; I inserted a roof family on my project now I try to delete it but I can’t; how to do?
Original post below.
j’ai un problème avec un projet que je suis entrain de faire; j’ai inséré une famille de toit sur mon projet maintenant j’essais de le supprimer mais je n’y arrive pas; comment faire?
@koutremonromain the forum language is English. This is a requirement t to make search work, otherwise I would use my posts as an opportunity to practice my Swedish.
Please translate all posts as I did in the edit of your post going forward.
To help with your issue, we would need to see how you inserted the family. My gut says that the family you see is actually just the geometry display from the form you have made in Dynamo, but we need some sfeeenshots of the Revit environment and the Dynamo graph which produced the new element.
