Family Instance by Point and Level
Hello everyone,
From linked element location I’m trying to insert some elements in my model but no matter what I do with the input point, the element constantly goes to 125,0,0. I did try to transform point by project base point and internal origin, but the result is the same. Do you have any idea? Did anyone have similar issue?
Also, after this, if I try to use set location but it will not move the element.
The Set Location node needs a Transaction node
Thank you for your reply. I know that set location need to be in a separate transaction. On the image above I’m showing get location. I’m not sure why elements are stuck at 125,0,0 no matter what I do with geometry transform. For some odd reason, when creating conduits with similar script I do not have problems with conduit creation.
Perhaps your level is attached to a scopebox that has that offset? But I would assume that the node grabs only the z-value of a level
