Family Instance by Curve Returns null
Ive never had a problem with this graph which ive used on multiple scripts. it normaly works flawlessly. but now the family instance by curve is returning ‘null’. The Family is a line based family. Any Ideas??
Revit Family :
Beam Clearance Family.rfa (352 KB)
Beam Clearances.dyn (17.3 KB)
Hi @ZJRODGERS
This happened after you install any package?
Try uninstalling clockwork package and install again.
okay ill try to reinstall but i just finished a graph moments before i started that one. And it had the same set up. Keep you posted
@Kulkul I unistalled and reinstalled. then restarted my CP. It still doesnt work.
@ZJRODGERS I downloaded and tested the script. I have no issues with the script. I ran it with Dynamo 1.3 and clockwork 0.9.x.
@NLDaniel I use that graph for alot of things that i do and it works on all my previous ones and not on this one… i might have to uninstall dynamo and reinstall it…
I Ended up reinstalling dynamo and it works now! thank you all for your input!
