Family Editor: Set yes/no parameters for all Types
Hi All,
I’m trying to set some Yes/No Parameters for all types in the family editor but just the current type gets changed.
Any idea why?
This is the code:
# Import RevitAPI
clr.AddReference("RevitAPI")
mgr = doc.FamilyManager
Types=list(mgr.Types)
_Parameters=FamilyManager.GetParameters(mgr)
for i in Types:
	for j in _Parameters:
		FamilyManager.Set(mgr,j, 0)
OUT=0
Did you make sure that all parameters were booleans?
Yes they are. It works just for the current type. I need to manually switch type if I want to run the script to the next one.
"FamilyManager.Set is used to set the value of a parameter for the current family type"
From this page:
Now you just need to add a line to set the current type for every type in the family.
http://www.revitapidocs.com/2018/3d37cd81-48ba-4011-82bc-dbb7ae14b270.htm
Try setting each type to current before setting params.
Looks like you are iterating over types but not doing anything with them:
for i in Types
    doc.FamilyManager.CurrentType = i
        for... # iterate and set param values
Thanks!
