Get Parameter from Current Family [FamilyEditor]
Hi all,
I found the Python script below from @Mostafa_El_Ayoubi.
https://forum.dynamobim.com/t/revit-family-parameters-value-family-editor/8499/7?u=mjb-online
# Import RevitAPI
clr.AddReference('RevitAPI')
s = doc.FamilyManager.CurrentType
pl = doc.FamilyManager.Parameters
Name_Parameter = IN[0]
p = [i for i in pl if i.Definition.Name == Name_Parameter][0]
UIunits = p.DisplayUnitType
vals = s.AsString(p), UnitUtils.ConvertFromInternalUnits(s.AsDouble(p),UIunits), s.AsInteger(p)
v = [v for v in vals if v != None]
OUT = v
It is exactly what i was looking for, but i doesn’t seem to update when running it for the second time.
Any ideas?
Hi @MJB-online ,
Are you in the family editor?
Yes i am (see topic title :slightly_smiling_face:)
What revit version you are using now ?
I use Revit 2019 and Dynamo 2.0.4 as a test environment
can help me send a dynamo dyn file you are running in to forum ?
Haha my bad.
Tested it working in revit 2021
testttt.dyn (3.9 KB)
rac_basic_sample_family.rfa (344 KB)
Hi @chuongmep,
What happens if you adjust the family parameter and run the script again? The first time it goes well for me, but when the parameters are updated, the python code retains the old value
you can try add flag true false if problem still cause, toggle true false to update value
# Import RevitAPI
flag = IN[1]
if flag:
	OUT = v
else: OUT = None
testttt.dyn (5.3 KB)
Thank you very much.
I was hoping there would be a solution without a toggle, but if not I’ll try this solution
I know an event can help you is IUpdate in Revit API but I think it is complex to apply in your case, but you can research it. IUpdater Interface
