Failed to specify the OmniClass parameter value of the family file
Hello, I would like to ask why the OmniClass parameter value in the family file cannot be changed? (Because I failed to use dyamo to change the OmniClass value of the component, I want to change it directly in Revit.)
Or I can only select the number provided by Revit and cannot enter it manually?
But the value I want to specify is not in the OmniClass list provided by Revit. The OmniClass manual I refer to is this.
https://download.autodesk.com/us/revit/OmniClassTaxonomy.txt
In addition, why the numbers provided in this txt are different from the OmniClass list provided by Revit?
And I found that when opening different family files, the OmniClass list provided by Revit will be different.
did you tried with python script, some thing like that ?
elementType = doc.GetElement(element.GetTypeId())
omniClassNumber = elementType.get_Parameter(BuiltInParameter.OMNICLASS_CODE)
OUT =. omniClassNumber
You might need to update the taxonomy file associated with revit.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-BA0B2713-ADA0-4E51-A7CD-85D85511F3ED
It works! Thank you!
