Fail to Load two packages access to the same API
Thanks @RMohareb
That did it. The issue does reproduce.
Dynamo does not support the same type (uniquely identified by Type.FullName) to be imported from distinct assemblies.
ex. type RevitAPI.RevitUtils cannot be imported from both RevitAPI.dll and SomeOtherAssembly.dll
Now in this particular case it seems we have at least 2 embedded interop types with the same FullName (from CivilConnection and BriMohareb) but are considered distinct by dotnet, so Dynamo will not allow it (based on the constraint mentioned above)
It does seem like the best course of action is to avoid embedding those interop types, if possible
Hi @tiberiu.pinzariu ,
is any other way to overcome this problem?
@zachri.jensen already solve it by use late binding and it is worke.
Did you had open source github ?
@chuongmep not yet
We currently don’t have any other way to fix this scenario. The best course of action is to do what @zachri.jensen said.
We will probably add this to the best practices documentation for dynamo authors.
Thank you both,
Tibi
We have added guidelines for using COM types in Dynamo
It basically suggests the steps described in this thread.
@tiberiu.pinzariu
is this thread change in Dynamo 3?
Hi @RMohareb
The COM interop documentation still applies going forward (including Dynamo 3.0)
