@Dimitar_Venkov, I am facing issues while giving input as bottom surface from linked model.
If I use importinstance.ByGeometry node it works fine but fixtures are hosted in that import instance. I need it to host on revit linked file.
i am not shure if you can host on a linked surface…
i would recoment to make workplane-based families… maybe there are other soltions for that…
when linked file get updated, you will also lose hosted elements, like dimensions.
KR
Andreas
