Rehosting The elements with linked model
Is there any way to rehost elements with a linked model or create a new element that hosts within the linked model? For example, placing lights on a ceiling that is part of the linked model. Any help or advice would be much appreciated
Hi @_Vijay something here for insert and host on link ceiling
PS not sure for rehost, but you can move without loose the host
Yes genius loci package :wink:
Revit_tdWV14NLNa
can you share the list of packages used? or the script
actually i have lights ad that need to host with linked celling. that hosting part is whare i am struggling.
allright so you have insert some light there dont host ? not sure we can host, in these cases i just insert again and delete the old…
any idea how can we place new one? since the host is in lined celling, i am struggling
my first image should do it
could you share graph please . or the packages used
i just use genius loci but you can use bimorph element faces there we get the link reference as well and use spring insert family…aand maybe wiyh ootb as well…but i like that one from genius loci
121Home.dyn (19.1 KB)
the location we need to set i think, i have it from CAD file. any idea.
no not sure if it not a revit element…can you share that cad ?
Here, need place linked arch file Celling.
Elec - Copy (2).dwg (196.7 KB)
yeah there we cant host, but just insert without host
Hi Vijay…you can insert this way here, but we cant host i guess
but need to host. look like need to manually no way to automate.
i guess you have a ceiling as well, link or not , then we can host, but need a revit element…
and these are host based families we can place with out host.
have with linked file.
yeah then use that as host, and insert in that location from cad…with genius loci
did you Explode the Cad files here? how did you get the location?
