Facing issue while giving input from link models
Hi, I am trying to place the light fixture but if I gave the “face” input from link models it doesn’t work. Is there any other ways to gave the input from link models
@balastarry ,
Check out BimorphNodes
2022-06-28_11h11_15
KR
Andreas
@Draxl_Andreas I used bimorph nodes to get the faces the ceiling but if I gave that input it doesn’t work. I get face output from Linkelement.face node after that I extracted the bottom face.
@balastarry ,
can you check list depth by face and point @L2
I tried that one, still same result
@balastarry ,
it works this way! check whether your family is workplane based!
@Draxl_Andreas I tried your method, For me its not working will suggest any idea
@balastarry ,
Are you indexing right? check if you have the right surface!
you can sort them by area f.e.
I gave bottom face only
Did you check also that the family has the right settings?
f.e. not vertical placed, not workplane, is it even surface based a.s.o.
@balastarry
ceiling has a thickness?
Hi @Draxl_Andreas the method you previously suggested is working fine with sample project which I tested, But if I folllow the same procedure for some other projects its not working at the last node i.e. Family instance by face and point node.
@balastarry , i mean depth a layer with a construction depth
I didn’t get your point
