I created a function to get all the button names. Unfortunately not getting the first button name. Not sure what is the exact reason.
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
app = uiapp.Application
fp = UnwrapElement(IN[0])
# Place your code below this line
config = FabricationConfiguration.GetFabricationConfiguration(doc)
#get all the loaded services
allservices = config.GetAllServices()
m_services = config.GetAllLoadedServices()
itemfiles = config.GetAllLoadedItemFiles()
useditemfiles = config.GetAllUsedItemFiles()
fabservicebutton = FabricationServiceButton
groupindex = fabservicebutton.GroupIndex
isstright = fabservicebutton.IsStraight
servicenames = []
for i in m_services:
name = i.Name
servicenames.append(name)
connectors = fp.ConnectorManager.UnusedConnectors
connectorList = [conn for conn in connectors]
connctorshape = []
for i in connectors:
shape = i.Shape
connctorshape.append(shape)
groupid = 0#fp.GroupId.IntegerValue
service = m_services[0]
groupcount = service.GroupCount
buttoncount = service.GetButtonCount(0)
def locateButton (service , groupid , name):
if service != None and groupid >= 0 and groupid < groupcount :
buttoncount = service.GetButtonCount(groupid)
buttonnames = []
count = 1
while count < buttoncount :
bt = service.GetButton(groupid, count)
if bt != None and bt.Name == name:
button = bt
button = None
count = count + 1
buttonnames.append(bt.Name)
comment = "null"
return buttonnames
OUT = locateButton(m_services[0], 0 , "Offset")
