Is the a way to know the service group of an element (MEP Fabrication Pipework). I looked up the Revit API 2020 and haven’t found anything.
Thank you in advance.
-biboy
-biboy
Hello @blsalvio
try this
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Fabrication import *
def getGroupName(lstServiceFab, fabPart):
famName = fabPart.get_Parameter(BuiltInParameter.ELEM_FAMILY_PARAM).AsValueString()
for servicFab in lstServiceFab:
for x in range(servicFab.GroupCount):
countButton = servicFab.GetButtonCount(x)
groupName = servicFab.GetGroupName(x)
for y in range(countButton):
fabServiceButton = servicFab.GetButton(x,y)
for conditionInt in range(fabServiceButton.ConditionCount):
condName = fabServiceButton.GetConditionName(conditionInt)
if fabServiceButton.ServiceId == fabPart.ServiceId and condName == famName:
return groupName
fabPart = UnwrapElement(IN[0])
fabConf = FilteredElementCollector(doc).OfClass(FabricationConfiguration).FirstElement()
lstServ = fabConf.GetAllServices()
groupName = getGroupName(lstServ, fabPart)
OUT = groupName
hi @c.poupin
i got the same solution. thank you. i was hoping for a document class api or fabrication class api for this one because I am afraid I have a lot of elements and its going to be processed in 4-5 for loops which will take a lot of time and computer resource.
anyways thank you again.
-biboy
