but the problem is that it doesn’t work when you have a parametric profile.
It just reads the lines from the family and doesn’t look at the parameter values.
I want to set some dimension parameters of my profile first… then get curves to make the solid by sweep.
is it maybe possible to duplicate a family so not a type but the complete family under a different name…then delete the types you don’t need and then run the pythonscript, then there is only one type so it should take the correct one.
I can’t do it with the standard family, because i am using multiple types of the family.
But i only see nodes to duplicate a type…not a complete family…
