Extract Sheet elements based on Sheet Number
Hi
I am trying to extract Sheet elements based on the Sheet Number (1). I have tried using Collector.Sheets (2). It works fine - almost… I want to have the full list and not only the unique Sheet elements (3).
What I want is to get all Sheet elements eventhough there is duplicates in the full list because I am combing this data list with other data about Revision (in this case).
Anyone with a good solution??
Thanks :slight_smile:
File: SheetElements.dyn (ver 1.0.1)
20160502-4
As an alternative, you could drive the list of sheet numbers through a list.map node:
