Updating Sheet Number
My aim is to change the sheet number by setting up an extra dummy sheet transaction in order to avoid duplicated number. How would I best filter out the corresponding elements from the sliced list?
And is this the best approach to do so
Much appreciated
Your nodes turn yellow because you are not feeding in elements (with the green number)
Hi Marcel,
How would I choose the actual sheet elements from (A105-A112) rather than the current strings? Do I have to filter.boolean them?
This should help you out.
The lists you are always filtering or slicing needs to be the original sheet elements.
Thanks for your response, that’s exactly what I’ve been looking for.
