Filtering Sheets by Sheet Name
Hi All,
I’m trying to filter sheets with python but I don’t know how to get elementid from sheetname. Any help would be great, thanks.
Script on left is not mine (still learning)
Hi @Lknapton,
Sorry to say the thing which you have done is not correct and not even close. I suggest you start first basic of Python. Below are some links for Python learning resources.
https://docs.python.org/2/tutorial/
http://www.ironpythoninaction.com/download.html
https://pythonprogramming.net/
http://wiki.theprovingground.org/system:page-tags/tag/python
Hi @Kulkul,
Your response is very crude and to be honest not helpful at all. I was given the script on left from work, as an example to learn from…
An example script or solution would have been a tremendous help.
@Lknapton
You can’t. Sheet name is a string.
You could search all sheets and try to find one with matching names, but since Sheet names are not unique, that’s probably not a good idea.
Check this example, see if it helps:
clr.AddReference('RevitAPI')
search_string = IN[0]
sheet_collector = FilteredElementCollector(doc).OfClass(ViewSheet)
matching_sheets = []
for sheet in sheet_collector:
	sheet_name = sheet.Name
	if search_string in sheet_name:
		matching_sheets.append(sheet)
OUT = matching_sheets
Thanks for this
