lasse
January 12, 2023, 3:46pm
1
Hello friends! When i am exporting a file in dynamo i end up with an empty .rvt file. How is that?
I can load in a .sat file and also export said .sat file into a .rvt file.
However this exported file is empty in the scene
Importing sat file dynamo (works):
Exporting .sat file into .rvt file (works but nothing is generated when opening file)
Could this be something with not saving the scene first?
Thank you!
EDIT: Manually saving the scene before exporting it works, so how can i automatically save the scene through dynamo? thanks!!!
@lasse ,
a .sat file works just in an corresponding enviroment there are two:
1.) A Projectfamily (it has to be in the work-mode)
2.) A family template
KR
Andreas
lasse
January 12, 2023, 4:15pm
3
Thank you for your answer!
Okay got it! Im new so i have not grasped the concepts quite yet.
This would be a family right since its a .rvt file?
@lasse ,
.rvt is a projectfile
is this mode you can place .SAT files
.rfa is a family file
(.rte is Projecttemplate)
lasse
January 12, 2023, 4:32pm
5
Thank you Draxl!
I seem to be able to export this scene to .rvt however as long as i run a dynamo script to save it
