Hello, everyone
I need to make curtain system based on floor contours.
So idea is follow:
- I take my floors to dynamo, select contours, calculate all parameters needed to make correct curtain systems and import curves to SAT file.
- Create mass family. Export SAT curves there, make mass
- Load mass to project and apply curtain systems to mass faces.
*-It will be better to make in-place mass through Dynamo, but I,ve read it is imposible.
**-Also it will be great to place curtain system on Dynamo loft surfaces but it also seems imposible.
So now I have a problem with export to SAT file. Node return me an error: Unable to write entity list as sat: NULL_FILE–null file pointer given. I have no idea what this means. Error is same for curves, points, surfaces - anything
