I just wanted to export a simple list to excel, but responded with “Operation fail”, how to fix the problem. please advise!
Hello, and welcome!
Even though I think your data is not structured correctly, it works as intended in my test. (images below)
Have you checked your sheet name? Dynamo is case sensitive. I get an error when spelling “plan1” instead of “Plan1”
What is the warning message?
Have you tried the OpenXML version?
Have you tried repairing excel?
I have the same problem, how did you fix that please ?
At first glance it OP only changed the level of the data input(was @3)
and a Code Block instead of the String node, but the latter shouldn’t matter(?).
Hi
thanks for your answer, I have used OpenXML version, now it works
