Hi all,
Got an error while trying to NWC export a view after applying multiple view template.
I got python Script which exports NWC. I added some codes to it to set view template before exporting every time.
It is setting the 1st view template, but shows error at line 41
Graph & Python script below…
from Autodesk.DesignScript.Geometry import*
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
import System
#doc = DocumentManager.Instance.CurrentDBDocument
folder=IN[0]
name=IN[1]
Element=IN[2]
Parameter=IN[3]
Paravalue=IN[4]
#exportoptionbldr=IN[2]
options = NavisworksExportOptions()
options.ExportScope = NavisworksExportScope.View
options.ExportLinks = True
options.ExportRoomGeometry = False
#uiapp = DocumentManager.Instance.CurrentUIApplication
#app = uiapp.Application
#uidoc=DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
#from RevitServices.Transactions import TransactionManager
#TransactionManager.Instance.EnsureInTransaction(doc)
if type(Paravalue) is list:
Result=[]
ind = 1
for i in Paravalue:
Result.append(Element.SetParameterByName(Parameter,i))
c=doc.Export(folder,"Export-" + str(ind) + ".nwc", options)
ind = ind + 1
Result.append(Element.SetParameterByName(Parameter,Paravalue))
c=doc.Export(folder,"Export-" + name + ".nwc", options)
#TransactionManager.Instance.TransactionTaskDone()
OUT = Result
Sample project & dyn
(Get All View node form Archi-lab)
Please help.
Thanks in advance…
I have a similar script.
Just before the line “doc.export…” I have a line that says
’options.ViewId = view.id’
I don’t see where you are setting this in your code.
This is necessary when ExportScope is set to View.
http://www.revitapidocs.com/2016/afec98fb-dba1-2413-baa4-6889550d8087.htm
Thanks ChainSmoker…
I added the view.id…but now the script exits silent…no error…But not exporting…Only setting the view template to view.
Changes done is adding the following…
view = UnwrapElement(IN[2])
options.ViewId = view.Id
import System
folder=IN[0]
name=IN[1]
Element=IN[2]
Parameter=IN[3]
Paravalue=IN[4]
Result=[]
ind = 1
for i in Paravalue:
ind = ind + 1
OUT = Result
Exiting without no error warning is not nice…
Any hints…?
I suspect it’s because the variable ‘view’ that you created is an array even though you are only passing one view into it and you need some way to iterate through that array when obtaining the view id. I dunno, maybe I’m wrong.
for i in Paravalue:
for v in view:
options.ViewId = v.Id
c=doc.Export(folder,“Export-” + str(ind) + “.nwc”, options)
ind = ind + 1
To be honest I’m fairly new to the python side of dynamo.
I am very new to Dynamo itself. Its only the 4th script. I thought this will be easy.
view was not a list at all. Interestingly the issue wasn’t with export side, it was with setting view template to 3D views.
So I did a different approach, after doing a lot of googling…But still result is same…Dynamo runs without error, but no export
But this time its bit more exceptions using this script … Multiple views => Apply multiple view templates => Export to NWC
New script…
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
viewtempname = IN[1]
prefix = IN[2]
folder = IN[3]
views = []
index = 1
for i in IN[0]:
views.append(UnwrapElement(i))
# Start Transaction
collector = FilteredElementCollector(doc).OfClass(View3D)#change to View3D
for i in collector:
if i.IsTemplate == True:
for v in viewtempname:
if i.Name == v:
viewtemp = i
for c in views:
c.ViewTemplateId = viewtemp.Id
vname = prefix + c.Name + str(index)
nop = NavisworksExportOptions()
nop.ExportScope = NavisworksExportScope.View
nop.ViewId = c.Id
doc.Export(folder,vname,nop)
index = index + 1
#for c, v in zip(viewelements,viewtemp):
#c.SetParameterByName(param, v)
#for c, v in zip(views,viewtemp):
# c.ViewTemplateId = v.Id
# vname = prefix + c.Name + str(index)
# nop = NavisworksExportOptions()
# nop.ExportScope = NavisworksExportScope.View
# nop.ViewId = c.Id
# doc.Export(folder,vname,nop)
# index = index + 1
# End Transaction
OUT = views
Change View Template_6.dyn (31.7 KB)
Sample file is in the thread above.
No idea what the issue is…
