Export DWG with Specific filename
Hi all i am new to dynamo and trying to get a specific filename after exporting. is that possible? is so i would appreciate your help. Thanks in advance.
Hi @interactiverendering
Your string file names contains special character β€œ/”. If you remove the characters then your good to go.
Great! It’s working fine now :slight_smile: Thank you.
@interactiverendering Mark the post as solved whenever you get a solution. Thanks :slight_smile:
Can you share your python script ???
@sarah.9090 he uses this script Export View Set To DWG
