I have problem because ListviewData isn’t working. I have 27 sheets and there is only one in the Listview Data. Also, the selection of the saving path is not displayed.
Hi @seba11 ,
Data-Shapes was originally build for Revit, so if you are using Data-Shapes in Civil3D some functions may not work, as they are dependant on some Revit libraries.
Could you open the ListView.Data node and check to see if there are some nested Revit dependencies in that Custom Node?
I use this dynamo in revit 2021
