Hi All,
This is my first time using Dynamo so bear with me if I am getting it all wrong, I have created a selection of four conceptual masses, there is some information I would like to get out to excel.
Family name
Family Type
Type parameter (height)
Gross floor Area
So far I have only managed to get one of these to export to excel (Gross Floor Area), I have tried loads of things but can not get the other information. Please can you help.
Hello Christopher Smeaton,
Can you please share your Revit file?
I think it should be doable.
Let me take a look at your file before providing any solution.
Thanks,
Ritesh
Dimitar,
This is fantastic and works great thank you. The only thing I can not do is the ‘Code Block’ would you be able to send me the file so I can check it.
once again thank you.
For Code Block you just need to double click in canvas and start writing.
I have added file for you here… WriteDataToExcel_FromMass
Thanks,
Ritesh
thank you, I got the over write section to work using the Boolean
this is the finished script, all I need to do now is figure how to bring the information back into Revit if I change it in the excel, the only things I will be changing is the height, and family names.
