Guys,
when you want to load family objects to project environment,
that objects must be seperated,
and has each names and volume,
How would you like to solve it?
The way I use ‘*.sat’ doesn’t seem right.
I’m looking for a different way.
you should use adaptive component family( 2 points or 3 points based) to manage you to separate each tunnel segment to have it’s own parameters like volume and name and you might add also start - end station if you need.
Thanks, ingenieroahmad.
I already tried adaptivecomponent.
Ultimately what I want to know now is how to separate objects created in the family environment when loading them into the project environment.
