I Have a Family that Contains Multiple “Imports in Families” and Need to Explode them to Use in Project
Using "Select Model Elements by Category " and “Imports in Families” i am able to select them into Dynamo and get there Geometry
But using “Geometry. Explode” it shows only list of Surface but import didn’t get Exploded.
and if tried to select multiple “Imports in Families” into Revit Explode option is Grayed out.
Thank you in Advance
Is each of those geometries its own import?
Why not move the geometry into a family directly from the source file instead of importing all of those objects?
What type of data is being imported?
Having the RFA or a small portion thereof would go a long way for others who m of her want to help - please post something if you can.
it is a Family that received from Client - Not sure about “Is each of those geometries its own import?”
I need to Assign Material to each Block for that Instance need to be Exploded.
Pattern.rfa (688 KB)
