Explode all imports within a selection at once
Hello great community,
You have provided me with many insights in the past reading different topics, though this is my first attempt at initiating a new topic.
I haven’t had much experience with coding neither parametric nor regular, though I have the will to learn so I am very thankful for any help you can provide.
I work for a company that models interior products in a typical CAD-software from which we do JT-exports and I use a plugin to import this JT-file into Revit. While there I can explode the different elements and attach materials and parameters regularly to the products. So far so good.
The issue with this workflow is that exploding each component within the products is very repetative and takes long. I would like to be able to select the objects and explode all of them, within my selection.
I have attached a video of how a product can typically look. This partical product consists of 53 individual components and they all need to be exploded. This seems to be a challenge for Revit seeing as each individual component needs to be exploded on it’s own.
Is this possible to solve with Dynamo, if so, could you help direct me regarding the node-packages needed and some tips on where to begin?
/Emir
Bumping this, would really love if if anyone could help with some direction :slight_smile:
I don’t believe that’s available in the API yet.
Nothing on this issue yet?
Not sure what a JT file is, but likely you can build the solid directly in Dynamo and the Revit API rather than producing them via import in Revit.
I don’t know what JT files are, either. I am looking for a way to “Explode” imported CAD elements in batch mode. Better yet, I would get the location of said Imported Symbols and replace them with native Revit ones so they do not appear in the Imported CAD elements report.
Doesnt appear possible in the API:
I realized that. Thank you for the responses. I’ve started the tedious process manually.
I wouldn’t recommend that.
Read the original DWG content into Dynamo and generate the families from there. If you set up the family template and are smart about how you do it you can even add parameters for materiality while you’re at it.
I am doing this to satisfy a VDCO request. The content is coming from legacy CAD dwgs that had been imported into the model at one time. I appreciate your concern, thanks for the warning.
