mika
#1
<pre id=“tw-target-text” class=“tw-data-text vk_txt tw-ta tw-text-small” dir=“ltr” style=“color: #212121;” data-placeholder=“Traduction” data-fulltext=""><span lang=“en”>Hello,
I started a bit on Dynamo and I try to create “color scheme” through an Excel file .
Read excel file , no problem .
But I can not find node to inform “Color Scheme” ; And I do not control the Python code .
If you have some help for me.
thank you</span>
Try bumblebee from the package manager, it greatly expands on the excel inter-operability.
http://archi-lab.net/bumblebee-dynamo-and-excel-interop/
also, here is a learning guide for bumblebee:
http://konradsobon.gitbooks.io/bumblebee-primer/content/
good luck!
mika
#4
thanks, for import export Excel it’s not a problem.
the probleme is to catch the color scheme setting
Color Scheme setting is not exposed in Revit API.
